Run Application installer and Publisher is Unknown
I made an installer for my application and filled in all the information of the company. But when I run the installer there comes a pop-up from windows and says Publisher Unknown.
How can I change this?
Thank You!
(5,108 Views)
This is a Microsoft issue. To be more precise: The installer does not include a digital signature.
There are little to no options for NI to help.
Norbert
Norbert
Expert: Geometry
(5,103 Views)
Accepted by topic author BBram
Norbert_B, that's not true - you can sign your executables and installers with a digital signature and apply that from the Build Specification. It *is* NIs job to allow you to sign the executable/installer with your own certificate.
You will need to generate a certificate and install it in Windows, you can then use it to sign you application. For it to appear as 'verified' (green), you need to use a trusted certificate provider (e.g. verisign etc.) to generate the signed certificate - this usually comes with a charge. You can create an un-verified certificate yourself - google it.
Executable:
Installer:
Here's the NI Knowledgebase on the subject: http://digital.ni.com/public.nsf/allkb/E06C1800F5AFCCBF86257236006C9F2A
(blog)
(5,089 Views)
Thank you for the information!
(5,060 Views)
@Sam_Sharp wrote:
Norbert_B, that's not true -[...]
You are correct, Sam. My wording was chosen badly.
My point was that NI cannot help you to get the signed certificate beyond the KB you linked (which i heven't seen before....). It is your task to get and apply the signature.
thanks for correction and elaboration
Norbert
Norbert
Expert: Geometry
(5,045 Views)
