Rs232 communication with pfeiffer vacuum single gauge
Dear all,
I am a novice in LabView programming but I managed to read WRITE and READ using VISA protocol the pressure from my single gauge (TPG261). When I tried to plot my pressure data on a graphic, I received some 0 value in between each pressure value. Please find in attached file the VI, and a screenshot of the front panel interface. I do not understand from where comes these zeros...
I tried to look into this forum without finding clues to help me with this weird event.
If anyone can help me a little bit on this, It would be very much appreciated.
Ps : sorry if this topic is not in the correct section of this forum.
Thank you
Best regards
(6,570 Views)
Hi Rémy,
big fail: don't open/init the serial port in each iteration of your loop! Call init just once before the loop!
- The sequence frame isn't needed in your VI!
- when you disable the "system dependent decimal separator" in the numeric conversion function you wouldn't need to exchange all points with commas in your received string… (Even better: set your OS/regional settings to use the point as decimal separator!)
- implement error handling in case you receive garbage data in your string…
(6,551 Views)
Dear GerdW,
First of all, thank you for your fast reply.
All your comments make sense and I am confident that it would work nice.I will have a look at it soon and I will get back to you with my feedback.
once again,
Thank you
Best regards
(6,546 Views)
Dear GerdW and potential readers,
I tried to take care of your advice but unfortunately I still get the same results. Please find in attached file the new version of the Vi. I may have wrongly interpreted your request ! If you have any though on this new file, it would much appreciated.
Thank you for your kind consideration
Best regards
(6,537 Views)
Accepted by topic author RémyMaury
Hi Rémy,
you still had no error handling in your VI! General rule: when you don't want to plot the zeros you need to avoid them as early as possible!
I also changed string conversion a little bit (please test this part for reliability!).
How does a typical received string look like?
(6,530 Views)
Hi GerdW
You are absolutely awesome ! This is exactly what I intended to do...
Thank you very much for your reactivity and expertise.
I wish you an excellent day but be sure that you have made mine !
Best regards
Rémy
(6,522 Views)
Dear Remy,
  thank you for your solution - I'll try this out.
Cheers
    -e-
(5,200 Views)
