02-28-2012 09:21 AM - edited 02-28-2012 09:23 AM
I cannot select a vi when I right-click > select vi from a folder or subdirectory. I can drag OK from a palette. I'm also getting a "flicker" of the window when I try to pull the vi from the folder. I'm running LV2011 and Windows 7.
Solved! Go to Solution.
02-28-2012 03:41 PM
So the only way to install subVIs is to select them from palettes? Have you tries restarting LV and Windows? With LV2011 I learned some time ago that if it is doing something strange, restart LV and if it's still doing it THEN it's a problem.
Mike...
02-29-2012 08:22 AM
Tried everything I could think of and then some. I even uninstalled 2012 beta to no affect. Still a problem. The only way I can get a subvi is to drag it from the palette.
02-29-2012 08:52 AM
Shot in the dark...
Blow away your LabVIEW.ini file (after backing it up).
Ben
02-29-2012 09:23 AM
I started looking at the timing of when this problem started. Turns out I had just installed "Ultramon" a 3rd-party mulitple display manager software. I use it at home and have had no trouble with it. I uninstalled Ultramon and right-click works again.
02-29-2012 10:47 AM
I ran into this problem myself and have a workaround. The old version of Ultramon 2.7.1 does not stop right click functions working correctly.
08-21-2012 06:35 AM
Hi All,
I have the same kind of problem. When I try to import a file using "Select a VI" in the right-click options, nothing is imported after selection is done using File Dialog. But when I drag the same file from Windows Explorer, the file is dropped in the Front Panel (or) Block Diagram without any problem. I hardly remember from when this is happening to figure out if some installation has caused this problem. Can any one help me how to make right click to work?
-Ajay
08-22-2012 09:50 AM
Ajay,
If you could answer a few questions for us to help you better with this issue, that would be great:
1. What version of LabVIEW/Windows are you running?
2. Have you tried to delete the LabVIEW.ini file and restarting LabVIEW/your computer?
3. Do you have UltraMON installed?
4. Is there anything else special or unique about your setup that we should know about?
08-22-2012 11:10 PM
David,
Here are the answers for your questions.
1. I have LabVIEW 2010 SP1 32 bit.
2. Yes I tried delete the LabVIEW.ini file. But still the problem persists.
3. No. I don't have UltraMON installed on my PC.
4. I have Real Time and FPGA Installed. I didn't do any modifications (or installations) w.r.t LabVIEW for past 2 months.
Ajay
08-23-2012 04:28 PM
Ajay,
Have you tried uninstalling any other (non-UltraMon) third-party windows UI enhancement utilities you might have installed on your machine? Also, what happens when you try this with a single monitor plugged into the machine?
If you could write out step by step what you are doing, so that I know we are on the same page, that will help me narrow down exactly what the issue is with your version of LabVIEW.
