11-26-2013 09:49 AM
This happens to me now and then in Labview 2009. I find re-booting my PC fixes the problem quite nicely.
Andrew
05-04-2014 02:30 PM
I am having the same problem and I use the same workaround (drag & drop using the project explorer works fine). But if I select a VI through right-click, Select a VI, it results in nothing being added to the block diagram. I see the same issue with LV2014 beta so my hunch is this is not a LabVIEW error but a problem with Windows 7. I think others on this thread as well as a similar thread are using Windows 7. In my case, I recently "upgraded" from Windows XP to VISTA and then to Windows 7. I specifically upgraded rather than perform a clean install so that I could retain my installed applications. I never saw the problem with XP, only when I completed the upgrade to Windows 7. If anybody else has a solution to the "Right-click, select a VI not working", I would like to know.
05-04-2014 02:49 PM
By the way, re-booting had no effect and I have never installed Ultramon. I am using LabVIEW 8.6.1 FDS and I have Windows 7 Ultimate.
05-05-2014 10:30 AM
Are you seeing the behaviour with LabVIEW 2014 beta or LabVIEW 8.6.1? LabVIEW 8.6.1 isn't supported for Windows 7, which could be an indicator if you're running into issues with it. For LabVIEW 2014 beta, I would direct you to post on the forum for LabVIEW beta.
05-05-2014 10:39 AM
Very strange problem which crops up from time to time on my Labview 2009/XP system. The last time, re-booting did not fix it. This time removal of applications runnung in the system tray did the trick (teamviewer 9 to be precise). No idea why... Since it happens fairly frequently I developed a workaround. Use CNTR to drag and make a copy of another VI, and then use replace.
05-05-2014 10:41 AM
My problem with right-click not working is with LabVIEW 8.6.1 on Windows 7. I was not aware that 8.6.1 was not supported on Windows 7. Thanks for the heads up.
05-05-2014 11:04 AM
I exited Team-Viewer and that solved the problem. From the block diagram I can now Right-Click "Select a VI..." and navigate to a vi. The selected VI shows up on the block diagram. Thanks for the suggestion Andrew_Scott_SPCi.ca
05-05-2014 03:04 PM
I just found another instance where TeamViewer messed with my work flow by breaking super quick drop.
http://forums.ni.com/t5/LabVIEW/Super-Quick-Drop-Fails-Me/m-p/2834182#M828208
The solution there was just to turn off the QuickConnect button in the Advanced options. I'm kinda curious to hear if that fixes your problem too.
Get going with G! - LabVIEW Wiki.
16 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
05-05-2014 04:46 PM - edited 05-05-2014 04:55 PM
Hello Hooovahh,
Yes that solution solve my problem (click on the menu/button to the left of the window minimize button, click "Disable this feature", click "Disable the QuickConnect button..."). I did have to quit and restart LabVIEW 8.6.1 but now I can leave TeamViewer open and select a VI using the right-click method. I have attached a Screen Shot of that QuickConnect menu for anyone else that has TeamViewer. Thanks.
02-12-2015 06:12 AM
I also had the problem that i cannot insert a VI by browsing (Select a VI) but i could drag a VI from Explorer.
As suggested here, I closed TeamViewer, and problem solved!!
