03-10-2016 08:10 AM
I have a large AF project with lots of classes and libraries. I only really use those two (lvclass and lvlib) to structure and organize the project. Right-clicking on VI's takes sometimes a terribly long time to load, say up to 10 seconds, depending on the library/class. It appears to be vaguely related to how much stuff the owning libraries/classes have. What specifically is causing this loading time? Any ideas how I could get rid of this significant inconvenience?
Here's more info and some thoughts:
03-10-2016 04:18 PM
03-11-2016 12:10 AM
I have to say I did desperately hope there would more to it than just that, the classes. Even if there's no resolution at sight it interests me: what is it exactly that the right-click menu has to resolve to such lengths?
03-11-2016 12:19 AM
03-11-2016 09:11 AM
I don't really have experience with this myself, but I have seen people talk about this before. Here are a couple of examples which might help you with what to look for:
Another thing which might be relevant is project providers (since you say this happens in the project). LV 2015 should now have the AF interactions as a project provider and you might have others installed, so this might also be the source of the issues. I'm not sure if there's a quick way to disable providers, although they should all live in <LabVIEW>\Resource, so you can try looking there, or possibly looking it up (there is a project providers group, but I believe it's private, so you might need to ask to join).
03-11-2016 01:22 PM
Thanks! I will take a good look at these and see what I can learn. The project providers particularly sound like something that might be very relevant. I'll try to find a way to test if they are.
03-11-2016 03:57 PM
@vekkuli wrote:Thanks! I will take a good look at these and see what I can learn. The project providers particularly sound like something that might be very relevant. I'll try to find a way to test if they are.
One that comes to mind quickly is the Viewpoint TSVN toolkit. With large projects the framework overhead can seriously bog down project explorer.
That being said, its an awesome TK! when you keep your projects down to a reasonable memory footprint like you should.
03-12-2016 05:20 AM
Thanks everybody for the ideas and resources. I'm very, very happy to announce that this particular fix https://decibel.ni.com/content/docs/DOC-44159 (Fix for AF Project Provider Performance Issue) made my issue disappear. Delay went down from ~7 sec to less than half a second. Wonderful! This, to me, proves false the idea that simply having hundreds of classes or a large AF project would make your routine IDE experience terrible.
