Is it possible to disable the right click shortcut menu in an ActiveX control? I know that I can do in a LabView control (right click on it --> Advanced--> Run-Time ShortCut Menu --> Disable), but I don't know for ActiveX controls, because they are different applications embedded on them and have their own events and shortcut menus...
Thanks for your reply. But sorry I can't understand you completely. For example, I drop an instance of an Adobe PDF Viewer into an ActiveX Container, and this control has its own Run-Time menu you can access by pressing right button on it (this menu isn't that every LabView control has, but an embedded one). Is it possible to disable it through LabView? I mean, I want to right click this control and don't want this menu to appear...
