08-18-2014 06:35 AM
could you help me. I have fluke 8508a conected with labview aplication via GPIB. I need to measure resistance ration on it. My fluke has front and rear output where i can connect resistors and get ration, but i have problem with labview and fluke 8508a drivers because i don't have that option in my fluke 8508a driver. Someone told me to try to find driver for fluke 8508a/01 because it has scan option that's used for ratio measuremens. Please someon help me with some advice how to make it work (ratio measurements).
Thank you in advance!
08-18-2014 06:48 AM
Got a programmer's manual? That should have the information you need. If not, then you need to talk to the Fluke tech support to get the commands that you need to send.
08-18-2014 06:52 AM
Do you know someone who had same problem?
08-18-2014 06:56 AM
Not this exact problem. But I've written plenty of instrument drivers that use GPIB, RS-232, and/or Ethernet. If a supplied driver doesn't do what you need, then you have to know what the commands are that need to be sent in order to get the instrument to do what you want. I spent 3 months digging throuhg a Tektronix programmer's manual trying to get the scope to do what I needed. That is just the nature of instrument control.
08-18-2014 06:56 AM
How can i contact them, because i can not find any mail for tehnical support,only phone numbers.
08-18-2014 06:58 AM
Then call them. Ask if they have an email support or a forums. You could also try Google to do a search.
08-18-2014 07:06 AM
My driver has "configure system.vi" where i can choose terminal(front, rear, difference...) but i dont know how to make that work like instrument( to take front and rear resistance value and divide it to get ratio). Here is some example of driver possibilities.
08-18-2014 07:09 AM
And Vi with "configure system.vi" block.
