10-21-2015 12:55 PM
I have a Boolean control ( switch when pressed ) and it is inside a while loop and the it is connected to the selector terminal of case structure. When the condition meets the boolean control should be changed to false. How can I programmatically set the boolean value without using local variable or value property node
10-21-2015 01:19 PM
I don't think that you can. Why don't you use "Latch when released" instead?
10-21-2015 01:55 PM
Exactly! Thats why we have Latcing mechanical actions! Change value untill the terminal is read once and go back to the initial state.
10-21-2015 02:49 PM
Nope! I got caught on this one a few months ago (and, in fact, LabVIEW Documentation has it wrong in several places, depending on the LabVIEW Version).
When the terminal is read, it goes back to its default value, not its initial state. Granted, in almost every (reasonable) program, these are the same thing, but I'm wearing my "Pedantic" hat, and (since I also "had it wrong") feel I should point out the subtle distinction.
Bob (Pedantic) Schor
