Report generation
i need to generate a report in Excel. i want to have a table in which some column entries should be manual and some will get data online.
How can i do this??
Thanks in advance..
(2,351 Views)
You can do either by using ActiveX calls to MS Excel properties & methods or by using the Excel VIs available with the Report Generation (which is a licensed addon) toolkit.
- Partha ( CLD until Oct 2024 🙂 )
(2,344 Views)
you have any examples on that??
(2,340 Views)
See here. Also, search these forums, you ll get a lot of examples.
But to see/use the VIs, you may need the RG toolkit.
Do you have it installed in you PC?
(2,336 Views)
Thank you, I will c..
(2,331 Views)
