Replacing the one column of data in txt file with headers
I have the data saved in txt format with headers like:
Date:
Sun, Mar 12, 2017
Time:
9:56 PM
Delta t (us)
499.999999E-3
Temperature (K):
300
Reactor Pressure (torr):
9.990000E+0
Time (microseconds) #$ Data
-5000.000000 0.000042
-4999.500000 -0.000003
-4999.000000 -0.000016
-4998.500000 -0.000033
I want to replace a column of data and save it as another txt file (there is a space between two columns of number)
from
0.000042
-0.000003
-0.000016
-0.000033
into
0.000050
-0.000008
-0.000018
-0.000039
Is there any way that the Labview program can read this file and transform it as another one with the same format?
Thank you.
(2,738 Views)
Your description is a tad confusing.  Can LV manipulate your data?  Yes.  But, what exactly are you trying to do?  You ask about replacing a column with headers (why wouldn't you just add headers and maintain the data?)  You also ask about swapping out a set of values.
Can you provide two examples of what you'd want your data to look like; one from before and one from after?  Not just a single column, but the entire data set?  If so, it'll be much easier to point you in a good direction.
(2,700 Views)
Accepted by topic author jimchu10
This can be achieve using string and array functions:
swap columns.pngHere the data is treated as dbl but string type can also be used. The rest of what you want to do is basic File I/O.
Ben64
(2,681 Views)
Thank you!
The two examples are shown as below:
Before (in text file):
Date:
Sun, Mar 12, 2017
Time:
9:56 PM
Delta t (us)
499.999999E-3
Temperature (K):
300
9.990000E+0
After (save as another text file):
Date:
Sun, Mar 12, 2017
Time:
9:56 PM
Delta t (us)
499.999999E-3
Temperature (K):
300
9.990000E+0
-5000.000000 0.000050
-4999.500000 -0.000008
-4999.000000 -0.000018
-4998.500000 -0.000039
(2,669 Views)
Thank you for providing the solution. I will give it a try and respond you after testing.
(2,668 Views)
