Replacing exe files & installers...
Ok, so I'm starting to work with distributions and had a question.... say I build an executable and installer, but once I start running it I find that I have a small glitch... nothing that would require extensive rewrite, but maybe I want to update a constant or two or change the font size here and there...  and rebuild my exe file.    Now, do I need to build a whole new installer or can I just take my new exe file and drop it in the target machine replacing the first exe file?
Thanks!
C
Message 1 of 9
(3,694 Views)
Accepted by topic author chuggins1434
For testing purposes, you can generally just replace your executable.  But you will want to rebuild your installer for the official release.
GCentral
Message 2 of 9
(3,692 Views)
Personally, I always build a new installer (but typically don't include run time engines and such). If you manually copy, the install tools might not know the actually installed version.
Message 3 of 9
(3,689 Views)
I'm with altenbach on this one. I also build an installer without the run-time add-ons each time, but this usually just because I have some support files that are deployed as well that I want to make sure I overwrite. If your application can simply be overwritten with the executable, that is the easiest way. Just make sure you do go back and test the full installer version right before release.
Cheers
--------,       Unofficial Forum Rules and Guidelines                                           ,--------
          '---   >The shortest distance between two nodes is a straight wire>   ---'
Message 4 of 9
(3,687 Views)
Ok, good to know... so, how far can you take it?  Where's the line you don't want to cross?  I'm thinking any mods to a sub-VI or channel changes that you're not going to update would be obvious, but updating fonts, moving buttons around, changing or adding buttons...    Thoughts?
Message 5 of 9
(3,679 Views)
Are you asking in relation to versioning? If you want a change in the executable, you have to rebuild the entire executable. Usually versioning is linked to the executable version, not the installer version.
Cheers
Message 6 of 9
(3,670 Views)
I'm asking in relation to the exe file...
Message 7 of 9
(3,664 Views)
Cheers
Message 8 of 9
(3,656 Views)
Gotcha... I guess I"ll just try a few iterations and see.   Thanks guys for the info and help!
C
Message 9 of 9
(3,651 Views)
