11-17-2010 10:51 PM
Confounded by this new problem.
Platform: Mac OSX 10.6.5 (this problem first cropped up while I was using 10.6.4 - I had previously no problems with 10.6.4)
LabVIEW 2010
I cannot suddenly open any instrument subVIs (subVIs created by me open fine) without crashing LabVIEW. It does not matter when the VI was created. I just cannot open the subVIs. I was able to, only last week (and before that).
11-18-2010 07:57 AM
That sounds like a file corruption problem. Can you obtain clean copies the the instrument subVIs from a different source to see if you can open them? If you post one of the VIs which causes your system to crash, perhaps someone can see what the problem is.
Lynn
10.5.8
11-18-2010 12:06 PM
I fixed the problem by reinstalling LabVIEW and moving back all the instrument VIs. Don't know what was wrong.
11-19-2010 07:38 AM - edited 11-19-2010 07:45 AM
Same here, update from 10.6.4 to 10.6.5 and then every time I open a VI a try to create a VISA resource name control LabVIEW crashes. Both LV 2009 and 2010 exhibit the same behavior.
By looking at the crash log, it seems that nipal has some problems when loading libSystem.B.dylib.
I'll try to reinstall VISA and be back to you about the result.
Ch
(BTW, look at the funny way the editor interprets the crash log by replacing ": D" with smiley)
11-19-2010 08:36 AM
during your re-installation did you reboot with the 32 bit kernel ?
11-19-2010 08:36 AM
Booting the kernel in 32 bits solved the problem!
Lets hope for a quick release of a 64 bits version of Visa and of course the rest of NI products line!
11-19-2010 08:47 AM - edited 11-19-2010 08:48 AM
Go to your Discussion Forum profile settings, My settings, Preferences, Display.
There is an option called "Emoticon Type" it is probably set on Use default (smiley). Change it to None.
Then
( : D without the spaces) will not show up automatically as ![]()
11-19-2010 11:07 AM
I did. I mean, I had to. LabVIEW on 64 bit Mac is currently useless (no 64 bit VISA) because NI continues to treat Linux and Mac customers as poor relatives while charging them the same amount of money.
My Profile | Privacy |
Legal |
Contact NI
E-Mail this Page
