Rendezvous inside parallel forloop
Do Rendezvous work inside parallel for-loops? I've been trying to use them, but something isn't quite right.For loop Rendezvuous.png
In the case shown above i can see the number of waiting threads keeps cycling 0-7 but never seems to catch all 8?
(2,209 Views)
That picture is too small to see what it going on.  You need to attach your actual VI.  Perhaps put in a bit more description as to what you are trying to do in this VI.
(2,193 Views)
So, This answer is yes. you can use Rendezvous inside a parallel for loop. Sorry it was hard to see there. I had an error and i couldn't probe anything. so i endded up making a rentrant subvi and figured out that there was an error in my logic. I dont like that you can't probe anything inside a parallel for loop. (Yes, i can enable debugging but then the rendezvous would be worthless.) But best just to make a subvi.
(2,187 Views)
By the way, depending on your browser. you should be able to open image in new tab or window... but then you can see it much better.
(2,184 Views)
