Removing Professional Development Suite
I have seen this before when portions of the install are manually deleted (ie if you delete the National Instruments Folder in Program Files). If you have the original media that you used for installation, you can do a repair install or run the installer from the command line with the \reinstall flag which causes it to overwrite already installed files. At that point the software should correctly show up in Add/Remove Programs and you should be able to remove it from the computer.
The other way is to manually delete the files from Program Files and use a registry cleaner to delete the registry keys, but I don't recommend that.
Jeff Peacock
Product Support Engineer | LabVIEW R&D | National Instruments | Certified LabVIEW Architect
Message 11 of 12
(394 Views)
Here is the standard uninstall already mentioned.
http://digital.ni.com/public.nsf/allkb/AC6ED75D3D93375686256E8E00245F0D
And as for MSI Blast it seems NI has been removing it from the forums.  There are external links still available as discussed in this thread.
http://forums.ni.com/t5/Multifunction-DAQ/i-am-looking-for-MSI-Blast-a-utility-to-remove-NI-DAQ-driv...
Here is another thread talking about it with an external link on the second page.
http://forums.ni.com/t5/LabVIEW/send-me-link-to-download-of-msiblast-to-unistall-labview-8-6/td-p/79...
Message 12 of 12
(371 Views)
