04-20-2015 06:28 AM
When using the Stacked sequence structure in my program, It is not working and I don't know the reason.
Without it, the program is working nicely.
Can somebody help?
04-20-2015 06:32 AM - edited 04-20-2015 06:32 AM
Hi LH,
when your VI "works nicely" without the SSS then why do you want to add it?
Well, when you want to know the reason you should either debug your VI or attach it, so we can look at it…
04-20-2015 06:32 AM
04-20-2015 06:36 AM
I need to use because my supervisor wants it for a nicer view at the end.
I put my project in the attachment.
04-20-2015 06:39 AM - edited 04-20-2015 06:40 AM
Hi LH,
In the end the look is NOT nicer. And in the end the code is harder to read. Tell that your supervisor!
Use a state machine instead of the SSS!
No, there is no PROJECT!
You gave us an office file in a proprietary file format. In that office file you embedded a picture of your block diagram.
Why not attach the picture in the first place? Why not attach your VI?
04-20-2015 06:42 AM
this is my vi
04-20-2015 06:44 AM
04-20-2015 06:48 AM
Is it a problem if I stayed on this thread?
My problem is that without the stacked sequence structure, my program is working and with it the program is not working. I want to know why? if this is possible and if not sorry for the disturbance.
I had learned Labview by myself three monthes ago.
04-20-2015 06:50 AM - edited 04-20-2015 06:52 AM
Hi LH,
that VI is bad. Very bad…
Why are there 4 buttons with the very same label?
Why are there 4 event cases looking at buttons of the very same label?
Why is there a timeout case set to wait for 0 ms? Why is there an additional wait in the loop?
Why is there an unwired reference output tunnel?
Why are there wires going from right to left in the first frame? Did you read the LabVIEW style guide? Did your supervisor read the style guide?
About the thread you are writing your message to: It is titled "Remove the SSS" and you insist of ADDING a SSS. See why your posts will not fit into this thread?
04-20-2015 06:53 AM
Ok,
Thanks and sorry for disturbance.
I will try to fix it by myself.
