03-20-2015 12:07 PM
I need to create an array of 2D Pictures. Due to the large amount of elements in the array, the picture width is reduced to minimum. However there's still a substantial gap between 2 adjacent elements in the array (see the attached example), which is caused by the frame of the picture control.
I tried to set the picture frame color to transparent, but even though it's invisible, it's still there. I also tried to customize the control, but I couldn't find a way to remove the frame (for both classic and modern styles).
(BTW, for classic style control, there's a unframed option of Color Box control, but no such option for 2D Picture control. And I need pattern/pictures inside the 2D Picture control element, so simple 1-color Color Box is not sufficient.)
Could anyone help to suggest a way to remove the frame and maximize the space density in the array? Thank you very much in advance.
PJI
03-20-2015 12:23 PM - edited 03-20-2015 12:27 PM
Hello PJI,
you should be able to set the frame smaller than the picture area of the control.
- Right click control and choose 'Advanced' -> 'Customize ..'
- In control editor change to 'Edit Mode'
- from the menu click 'Window' -> 'show parts window'
- In the part window select the frame
- set new values for top, left , hight and width, so that the frame hides behind the picture area
Hope this helps.
UliB
03-20-2015 12:39 PM
It works. Thanks!
