06-13-2016 08:04 AM
Hello all,
I am able to trace an application remotely with the DETT 2015 (Desktop Execution Trace Toolkit) as described here:
http://digital.ni.com/public.nsf/websearch/A50A8BBFD737679186257D7700688757
http://www.ni.com/white-paper/8083/
But my problem is:
When I double-click on entry, it tells me it cannot highlight the VI.
(see attached screenshot)
What I am doing wrong?
I have created in this way:
1. create new very small LV2014 SP1 (14.0.1f3) Project
2. create EXE from it (with all needed configs: see below)
3. copy EXE to remote PC
4. from LabView: My Computer->right mouse click->start Trace Execution
5. In DETT connect to remote computer and application
6. start DETT
7. start Application on remote-> OK, there are new entries in DETT arriving
8. double click on one entry-> It tells me, it cannot resolve VI
Copied "Desktop Execution Trace Toolkit" Folder to "C:\Program Files\National Instruments" on remote -> Did not help.
Also tried with DETT 14 (on other PC) -> did not help
my config file:
[DETT_Test]
server.app.propertiesEnabled=True
server.ole.enabled=True
server.tcp.acl="long-hash"
server.tcp.enabled=True
server.tcp.port=3634
server.tcp.paranoid=True
server.tcp.serviceName=""
server.vi.access="+*"
server.vi.callsEnabled=True
server.vi.propertiesEnabled=True
WebServer.TcpAccess="c+*"
WebServer.ViAccess="+*"
DebugServerEnabled=True
DebugServerWaitOnLaunch=True
06-15-2016 04:16 AM
does your executable work properly on the remote PC? Maybe there is something missing.
Best,
anna
06-15-2016 03:24 PM
My executable works fine. That is not the problem.
Perhaps the problem is with the "VI in EXE Path" (behind EXE path) ?
see attached image
Is anybody able to trace a remote application, double click on the trace entry and it jumps into LabView code?
