Remote User Events Library using VI Server
I posted a reference library for creating User Events in LabVIEW that can be accessed over the network in the Community page. Check it out! It uses VI Server to enable sending the data across. It is based on the standard LabVIEW User Event functions, and is polymorphic to handle the following data types:
  • String
  • Object
  • Variant
  • Boolean
  • Command (cluster containing String command and Variant data fields)
I think this could be very useful. I use User Events all the time for their flexible many-to-many messaging format, and this provides a way to abstract that same syntax across the network.
Community Link
Example Server
Example Client
Jarrod S.
(3,385 Views)
Is it possible to save these useful remote function in LabView 2009 please.
Regards Gary
(3,194 Views)
Do you have an example client that would work for a cRIO?
(3,185 Views)
I dont have a use for these at the moment, i was asking if someone could possibly save these functions so i could use them in the future in LabView 2009.
Regards
Gary
(3,164 Views)
Sorry - I meant to ask Jarrod if he had an client example that was tailored for the cRIO.
(3,156 Views)
