06-08-2009 02:40 PM
Hey everyone,
I would like to view and control a VI front panel from a computer that is connected on the local business intranet. First, I used the web publishing tool on the computer on which the VI is located to publish the VI, then I hit connect. Next, I went on another computer connected to the business intranet and selected "Connect to Remote Panel..." and connect with "Request Control" checked. After I select "Connect," a message is returned saying "Server does not support Remote Panels." Any suggestions?
Owen
06-08-2009 02:53 PM
Well, my first question is, have you enabled the web server service on the host computer?
Tools >> Options >> Web Server : Configuration
Then on the top, check the box that says "Enable Web Server"
06-08-2009 03:04 PM
06-09-2009 03:45 PM
Hi owen,
Have you searched NI.com for your error? Often times this is the best way to get resolution to your issues. I searched for "Server Does Not Support Remote Panels" and found this as the first result:
"Server Does Not Support Remote Panels" Error When Connecting to a Remote Front Panel
06-09-2009 03:57 PM
Hey Stephen,
Thanks for taking the time to respond. I have resolved this issue, but have come across another in the process. Thus far, I have been able to remotely control VI's through intranet from remote computers. Ultimately, my goal is to be able to remotely control a VI which is acquiring data, without the use of the internet and without the use of a router. Right now, as far as I know, this requires that I create an ad hoc WiFi network between the host and client computers; I have been successful up to this point. I used the web publisher in LabVIEW on the host computer to publish, but when I try to load the page on the client computer, the status bar stays unfilled and reads 0.00% of 0 bytes. I have tried waiting a long time for it to load. Also, I have successfully published, viewed, and controlled the VI on separate computers with the intranet operational, the only problem is when I try to remotely control the VI through the ad hoc network. I have searched the web and the NI Discussion Board thoroughly, but have found no solution.
-Owen
