06-17-2014 04:20 AM
If we look into Traditional DAQ for the AO Write.Vi,we will have an inpput called as Allow Regeneration (true or False),
I need that kind of input to be set to the DAQmx write (so that based on the boolean condition it should regenerate). Can any one help me on this , whether that is possible or not.
06-17-2014 08:22 AM
Drop down a DAQmx Write property node. One of the properties you can set is Regeneration Mode. It is a ring to set the value, so you will need a Select node in there if you just want to use a Boolean.
06-17-2014 12:43 PM
Thanks a lot crossrulz ,
Sorry i got it to some extent , i know the daqmx property node and selecting regen mode which is a ring after that how do i control it as boolean can you please tell me in steps.
06-17-2014 12:47 PM - edited 06-17-2014 12:47 PM
Use the Select node.
06-17-2014 12:49 PM
Thanks a lot crossrulz...great response..
