10-10-2005 07:07 AM
10-10-2005 07:11 AM
Here is the block diagram of the auxiliar subVi. If somebody needs more information, please just ask.
10-11-2005 08:41 AM
I would thank so much if somebody can give me some idea. This function is not working at the moment (or I suppose so) and I should solve it.
10-11-2005 11:22 AM
It appears you are using an ActiveX control, and this ActiveX has callback events wherein on some specific task happening, it "calls back" LabVIEW to inform about it. You get to know about these callbacks when you register for them. That's what the Reg Event Callback is for.
The VI to the left of the reg node is the callback VI, i.e., it gets called or run rather when you get the callback from the ActiveX Control. To debug, you can start off by putting a message box in the callback VI. This way a msg box will popup whenever you get the callback. And you can go from there.
Hope this make sense.
-Khalid
10-11-2005 12:26 PM
A callback is a function which is called (when it is registered) when an activeX event happens. The Vi is strictly typed and defined by the activeX event associated with it. This is a nice feature if you plan to incorporate activeX controls in an event driven programming model. An example is on double click for an activeX event .
Paul
10-12-2005 03:48 AM
Ok, thanks a lot for both, it is giving a bit of light.
Yuju!
