05-08-2015 12:39 AM
Hi, is there a way to make the following codes run much faster without changing too much? The goal is in the code.
Solved! Go to Solution.
05-08-2015 01:16 AM - edited 05-08-2015 01:32 AM
Yes, there is. Try the "Sieve of Eratosthenes".
My old prime code does it in less than 50ms on an old laptop. Is that fast enough?
05-08-2015 01:32 AM
I know but it's an assignment, so we are not allowed to use someone else's codes.
05-08-2015 01:35 AM
You are working in UCLA? I think I know who you are. Kyle mentioned you in our workshop before. Hope I can meet you in person!
05-08-2015 01:44 AM - edited 05-08-2015 09:51 AM
OK, looking at the code, you seem to be using the sieve, but there are many very inefficient constructs.
Here are some ideas:
05-08-2015 01:46 AM
Yes, I know Kyle. 😄
05-14-2015 12:27 PM
Thanks so much, Christian.
05-14-2015 12:29 PM
In order to compare code, you also need a good benchmarking procedure. How fast did you get so far? 😄
05-14-2015 12:37 PM
I actually submit a rather navie solution of mine for grades and it takes 0.6s. But I will still study your solution later for a deep understandning of prime numbers. Let me post my submitted soulution here.
05-14-2015 01:17 PM - edited 05-14-2015 01:19 PM
I have not verified the code, but here are some very general comments:
