in the meantime I tried with a very simple program:
#include
int main(int argc, char* argv[]) {
short DAQCard;
int res=0;
Init_DA_Brds (1, &DAQCard);
// route A
res=Select_Signal ((short)1, ND_IN_START_TRIGGER, ND_PFI_0, ND_LOW_TO_HIGH);
// route B
res=Select_Signal ((short)1, ND_RTSI_0, ND_IN_START_TRIGGER, ND_LOW_TO_HIGH);
return 0;
I set a break point at 'return 0' and tried all combinations of A and B by commenting them out or swap. In neither case the signal on PFI0 appeared on RTSI0. Of course the card ID is 1.
I assume that a triggered acquisition must be activated to get the PFI0 propagated?!
Tobias
