I am developing an application on a PC, and while I was away one day, someone needed to move the PC. When they did that, I was in the midst of development, so some VIs were not saved. After I got the PC back, I noticed that I lost a lot of work on one VI. I looked at the autosave folder, but it is empty. What are other ways to recover my work? Thanks!
If the autosave / project recovery don't give you any help then I don't think there are any, unfortunately. Saving often and using source control to back-up your code is the only reliable way to avoid losing code! Hindsight is 20/20.
