10-28-2015 11:20 PM
Hello all,
I am having an incredibly frustrating problem. My RT PXI chassis has decided that something has gone wrong. I am not sure what that could be, but now it boots into safemode attempting to reboot three times. I have never been able to retrieve the error log via MAX (I get time outs), but if I go into the physical drive via ftp and poke around in the errorlog.txt, I find the most recent error:
10/29/2015 03:25:09.153 0 -2147220694 000 Incompatible schema detected, but no specific DD can be identified as the source.
Please refer to "c:\ni-rt\system\mxsSchemaError.log" file for more information.
CmxsNeoStorage::ValidateDBStructuralIntegrity()
If I go to the file it refers to, I find the following error:
[10/29/2015 03:25:09] *** COLLISION DETECTED *** between object with NeoID:0 of class Database_Header located at 0 (256) and free-list 1 (28344)
[10/29/2015 03:25:09] Incompatible schema detected, but no specific DD can be identified as the source.
Anyone have any thoughts on this? I have tried uninstalling all of the software and then reinstalling. Everything seems to be ok until I install DAQmx drivers and there dependencies. But, I don't think this is directly related to DAQmx. I think it is ties up with one of the dependencies. Any input is helpful (although I want to avoid having to format as I don't have a recent copy of the MAX configuration for the system).
Cheers, Matt
Solved! Go to Solution.
10-29-2015 12:22 AM
Looks like a corrupt databse :(...
Likely will have to reboot the configuration.
10-29-2015 09:58 AM
Have you changed LabVIEW versions recently (say, from 2014 to 2015)? You probably need to check/update the software on the PXI.
If all else fails, it is not all that difficult to "start over" with a reformatted hard drive on the PXI and install a fresh RT system, particularly if you have a controller that doesn't boot from a floppy (don't ask -- we have lots of 8176's).
10-29-2015 11:16 AM
Nope. This seemed to happen magically (as all of these problems seem to arise). This is the second time in a year this seems to have happened and I think that I must have something wrong with my network settings on my development computer because I have been unable to import a copy of the MAX configuration file. Soooo, given this, starting over is an abominable option. My most recent backup of the file is stale and so I am going to have to rebuild the configuration file from my notes. This may be a horrible lesson learned about using the MAX configuration file. Ugh...
10-30-2015 12:08 PM
Bob,
I marked your answer as the correct one, but I wouldn't say this is a particularly great one. This exposed a major weakness in using the MAX API to configure tasks. I will probably move my configuration into the code itself (as well as a custom INI file for this) so that I don't have to deal with this in the future.
Thanks for taking a look at this.
Cheers, Matt
10-30-2015 10:21 PM
Matt,
Sorry to hear your system is being flaky. Have you tried creating and saving your Tasks in LabVIEW Project? When I first introduce students to DAQ with LabVIEW (using a USB-6009), we "play" with MAX and I show them how to create and save a Task (in MAX) that they can use to store the details of the configuration. But I discovered when configuring my Real Time Tasks on a PXI, this seems to associate the Tasks with the PXI, not with the Project and the code, so I switched to specifying the Tasks in Project. Now I can develop on one machine, save the Project in Subversion, Update on my "target" machine, and the Task is Ready to Roll, even though the PC and PXI are different.
