02-18-2013 10:07 AM
It works correctly, but it fails to incorporate into my VI. 😞
02-18-2013 10:29 PM
What else you want
02-19-2013 01:51 AM
I do not know how to build a VI with a chart in my VI to work. I still have not succeeded. Thx
02-19-2013 03:13 AM
If you want help in some component then you should add that compponent in your posted VI otherwise we dont know what is your application or where you want to add this graph
02-19-2013 06:47 AM
I added it into my VI where I would like.
02-19-2013 09:29 AM
You've already been told to acquire a waveform datatype in order to display actual time on the x axis. You have no time data in that 1D array you are acquiring. If you don't want a waveform datatype, look at the shipping example called Real Time Chart. This is where you provide the offset and multiplier that the chart needs to get the time. Unless you provide the time information, the chart cannot display the actual time.
02-20-2013 07:13 AM
I am confused now . Could someone do for me into my VI which is one post above?
02-20-2013 07:23 AM
Dear Devj!
All you have to do is to go to DAQmx Read, and select Analog > Multiple Channels > Single Sample > 1D Waveform. You can wire the output array directly into the display.
I've done this change in your VI, please check if this is what you want.
Regards:
Andrew Valko
NI Hungary
02-25-2013 03:35 AM
Sorry that I reply so late, but I was now busy. Its going good, but now I have problem with displayed digital value of voltage. I cant stack plots and I can display only one digital value of voltage. Some tips how can I fix it?Sorry that I reply so late, but I was now busy. Its going good, but now I have problem with display digital value of voltage. I cant stag plots and I can display only one digital value of voltage. Some tips how can I fix it?
02-25-2013 06:53 AM
Same reply, your VI please (2011 compatible)
