Reading from CO2 sensor connected to the PC
Hi Raven
Just like this :)?
I guess you are right. If I try to press the stop button in the first loop it just gives me the same error before changes were made.
Greetings
DP
Message 61 of 63
(366 Views)
I would first apologize for responding so late.
I have solved the problem I had at that time and it is all because of you guys. Each one of you helped me out in a big way and taught me alot. I would like to mark a solution but I guess I can not just mark one post as a solution as more than one contributed to solving the problem. What do I do here 🙂
Greetings
DP
Message 62 of 63
(338 Views)
DP123 wrote: I would like to mark a solution but I guess I can not just mark one post as a solution as more than one contributed to solving the problem. What do I do here 🙂 ?
You can mark more than 1 post as the solution...
GCentral
Message 63 of 63
(335 Views)
