05-06-2013 03:18 AM
Hi Enriquez,
you have an array of pixels. All you have to do is using the correct indices to read the pixels values! Come on, just some simple math involved...
Is it so hard to calculate the needed x/y indices?
Where do you find the center of the image? Something like x-size/2 should do the trick...
05-06-2013 04:32 AM - edited 05-06-2013 04:33 AM
@Enriquez wrote:
What I meant is how do I manipulate the array to read from the center to the right diagonal? and how do I make another graph that shows the upside down result of the radius graph?
Hi enriquez!
Maybe you are supposed to look "straight forward" on the output array of the "unflatten pixmap.vi" which is called "24-bit-pixmap" in the attached .vi
Is this what you are looking for, or did I get you wrong?
05-06-2013 04:33 AM
oh and how do I delete all duplicated entries in the 2D array output after the Split number function? So that I have 1 entry instead of having 3 of the same duplicates
05-06-2013 04:46 AM
05-06-2013 10:13 PM
Hi alexderjuengere!
Thanks for the help but unfortunately I couldnt open your vi as Im using the older version~
05-06-2013 10:41 PM
Yes we're working together!
we're using version 9, could someone help us to convert over to version 9?
Thanks!
05-07-2013 03:20 AM
Hi alexderjuengere,
Thanks for the help once again!, the one that you gave me is what I'm looking for.:)
