09-06-2016 05:11 AM - edited 09-06-2016 05:11 AM
Looks reasonable - but I don't know if it's correct because only the developers of the website can answer that question 🙂
As I said before - you say it "doesn't work" - but what do you mean - do you get an error? What response headers/body do you get?
09-06-2016 05:27 AM - edited 09-06-2016 05:28 AM
As output no value .
body = empty .
headers = empty.
error: 363506
LabVIEWHTTPClient.lvlib:POSTBuffer.vi:6120001<APPEND>
<b>Complete call chain:</b>
WebService_POST.vi
09-06-2016 06:43 AM - edited 09-06-2016 06:44 AM
Is there an error message that comes with it? Normally you get more information than just the code and the error source which would indicate the reason for the error. These are basic steps for troubleshooting issues with your LabVIEW code.
Right click on the error indicator and select 'explain error':
09-06-2016 09:29 AM
The problem seems the certificate, this error:
LabVIEW: The certificate path or CA information of the local host is invalid.
In CONFIG SSL function should I put both certificates ( CA and CLIENT ) or one is sufficient ? which? and where is it ?
I'm sorry for the many questions but I can not find information.
THANK YOU
09-06-2016 09:39 AM
09-06-2016 10:51 AM
09-06-2016 10:54 AM
I tried it with OFF verify server and any attached certificate , it returns a header but empty body and no errors .
09-06-2016 11:20 AM
Just want to throw in here that it looks like aliexpress has a documented public api: http://portals.aliexpress.com/help/help_center_API.html?spm=a2g01.8078014.0.5.ZpKuEo
It shows you how to build up the urls and documents input parameters, output parameters, errors, etc.
If the API provides the data you are looking for it will probably be significantly easier to get the data you want. The public API also has the benefit of being supported by the company.
09-06-2016 11:20 AM
And what is in the headers?
09-06-2016 11:24 AM
HTTP/1.1 302 Found
Date: Tue, 06 Sep 2016 16:23:24 GMT
Content-Length: 0
Connection: keep-alive
Set-Cookie: ali_apache_id=10.182.248.33.1473179004909.271347.3; path=/; domain=.aliexpress.com; expires=Wed, 30-Nov-2084 01:01:01 GMT
Server: Apache-Coyote/1.1
P3P: CP="CAO PSA OUR"
Location: http://sec.aliexpress.com/query.htm?smApp=globalsearch&smPolicy=globalsearch-globalsearch_category-a...
Content-Language: en-US
Strict-Transport-Security: max-age=0
Timing-Allow-Origin: *
