08-28-2015 11:29 AM
I have a large amount of excel data files I am reading into a labview program. I want to use the date created property of the files to select only files in a date range. How do I read this file property?
Solved! Go to Solution.
08-28-2015 11:34 AM - edited 08-28-2015 11:35 AM
It's dangerous to go alone! Take this.
Cheers
--------, Unofficial Forum Rules and Guidelines ,--------
'--- >The shortest distance between two nodes is a straight wire> ---'
08-28-2015 11:38 AM
Thank You! That helped.
08-28-2015 11:42 AM
No problem! In general, you can get all of the information you need that you could normally get using Windows, you just have to use the Windows API.
Cheers
