01-28-2015 01:14 PM
Hi all,
I have a LeCroy WaveAce 214 Oscilloscope and I want to data from it (voltages) into LabVIEW. I have done so looking around and there are no LabVIEW drivers for these models that are a little bit older, but they do come with there own software that can read the waveform and read the data. So what I would like to do is take the data in using one some of there software like WaveStudio and save it to the computer, and then read it into an array in LabVIEW. I would like to do this quickly though so I'm taking and reading data every couple seconds and filling an array with it. Has anyone ever tried this? or does anyone have any suggestoins about trying this?
Any thoughts would be great!
also using LV 2013
01-28-2015 01:20 PM - edited 01-28-2015 01:32 PM
Edit: My apologies if you have already looked at these. But I've had luck using an older driver on a newer machine if you want to do some tweaking. The following link will send you back to NI's LeCroy driver page. You have a lot of choices. Something should work.
About half way down this page there is a link for LabVIEW drivers.
01-28-2015 04:45 PM
If nothing else, it should be hard to create your own drivers. You just need to know what commands to send. There should be a programmer's manual somewhere for your scope.
01-28-2015 09:42 PM
