NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
Ori Idan
Reading CTS or DSR lines of Serial port
Is there a way to read the status of CTS or DSR lines of a serial port?
Also in what pins are these lines on standard PC?
Ori Idan
Helicon technologies LTD. National Instruments Alliance member in ISRAEL
Email: ori@helicontech.co.il
Home page: http://www.helicontech.co.il
Tel: +972-6-6262353 Fax: +972-6-6262405
Things should be made as simple as possible but not simpler
Albert Einstein
Member
Vlad Dragomir
Re: Reading CTS or DSR lines of Serial port
Hi!
You should try this using VISA function, which can be founded in Instrument
I/O->VISA pallete. If you open a VISA session foe a serial instrument, you
will be able to acces various parameters of the serial port, includind reading
the CTS and DSR state.
Vlad Dragomir
Member
Steve Drake
25pin 9pin Signal Direction Description
1 - - - gnd
2 3 TD DTE>DCE tx data
3 2 RD DCE>DTE rx data
4 7 RTS DTE>DCE request to send
5 8 CTS DCE>DTE clear to send
6 6 DSR DCE>DTE data set ready
7 5 - - signal ground
8 1 DCD DCE>DTE data carrier detect
20 4 DTR DTE>DCE data terminal ready
22 9 RI DCE>DTE r
ing indicator
23 - DSRD DCE<>DTE data signal rate detector
Think of DTE as the computer.
I don't memorize this stuff it comes from a very usefull book called
"The Indispensable PC Hardware Book" by Hans-Peter Messmer.
While I've used the serial vi I didn't have to use the control lines
so I have no experiance there.
Hope this helps.
Steve Drake
Member
Steve Drake
While looking for info on printing I found the following:
How can I control the DTR and RTS serial lines?
Serial Port Init.vi can be used to configure the serial port for
hardware handshaking; however, some applications may require manual
toggling of the DTR and RTS lines. Because the interface to the
serial ports is platform-dependent, each platform has a separate
mechanism to control the lines.
(Windows) The LavVIEW for Windows distribution contains a VI which you
can use to drive the DTR and RTS serial lines. The VI serial line
ctrl.vi, located in vi.lib\Instr\_sers
up.llb, can be used to control
these lines. The VI will toggle these lines according to the function
input. Valid codes for the input are:
0 noop
1 clear DTR
2 set DTR
3 clear RTS
4 set RTS
5 set DTR protocol
6 clr DTR protocol
7 noop2
(Macintosh) ..................
(Sun).............................
From LabVIEW User Manual page B-13
Hope this helps.
Steve Drake
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
