03-18-2015 08:12 AM
Hi.
I want to send some numerical values to a pci card (already have solved the channels you are) and want it to be read from a graph or a text file (the volores-axis are in one column and the values of the X axis in another ) I do not know which one I find it easier to read.
Anyway me of the value output axis but in real time, that is, if I have a constant value of 4 seconds want in those four seconds me is dialing the output value or values grow or shrink I want to check the output the same.
The X axis is time.
Any idea if it's easier to read a chart or a txt and what features should I use?
03-19-2015 10:20 PM
I'm very unclear about what you want to do, but I'm especially puzzled by the notion of reading from a graph -- I think (perhaps incorrectly) of a graph as an output, not an input, that is, you write to a graph, not read from it. A text file, on the other hand, allows both reading and writing ...
BS
03-20-2015 12:53 PM
HI Bob_schor
What I want to make a program that handles a cylinder.
I keep a txt force (daN) I want to make the cylinder.
Then I read the displacement (inch) made in the trial.
But I do not know whether to force the command to read a txt or a graph do myself.
03-20-2015 01:01 PM
It sounds like what you want to do is set up ahead of time the waveform that you want the PCI device to output (either by reading it from a text file or designing it using controls in your software, in which case it would also be displayed on a graph as you design it), send this waveform to the device, (either as a Waveform data type or array(s)), and then have the device output the waveform in real-time.
Is this correct?
03-23-2015 01:18 PM
hi Vltan
Attached is a photograph.
1.I like the cylinder did this shift in that time.The displacement data loaded from a txt.
2. Save at that moment the force used by the cylinder to make that shift.
Why where I can start?
