NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
avinash3010
Accepted Solution
Read integer values from spreadsheet and display the values in a table
Hi all,
I have integer values to read from a spreadsheet and display them in a table. I am using 'Read from spreadsheet file' in 'integer' mode. I would like to display these values in a table. The problem is that the table takes only 2d-array of string as input but not integer.
It works fine if I change the mode of 'Read from spreadsheet file' from 'integer' to 'string' but I want to read integers and have to use the integer values for further calculations. Please give any suggestions on displaying integers to a table.
Thank you.
Active Participant
P@Anand
Re: Read integer values from spreadsheet and display the values in a table
You do the same thing but in the display part convert that into string and display them but for the other numeric operation you can take the values from the numeric that you are reading from the spreadsheet.
I don't believe in Hard work. I love my work :smileyhappy:
Member
avinash3010
Hi Anand,
I tried converting each element into a string by using index array and build it back into an array of string but it failed to dsplay.
Thank you.
Trusted Enthusiast
TiTou
Can you post your VI that fails?
________________________________________________________________
"Cambiar el mundo, amigo Sancho, que no es locura ni utopía. sino justicia."
Cervantes
Active Participant
P@Anand
No don't take element by element just convert as a whole. See the attached example
Good luck
Member
avinash3010
Thank you Anand...it is working..
but it is displaying the decimal places with zerors. any suggestion to remove this?
Active Participant
P@Anand
Then use Numeric to Decimal String function.
Member
avinash3010
Thank you very much.
Member
avinash3010
Hi TiTou
Sorry for not posting the VI. I got the solution before I could post. Thank you verymuch for replying.
Trusted Enthusiast
TiTou
No worries, glad to see you've got a solution :smileyhappy:
Cervantes
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
