06-22-2006 02:06 PM
06-22-2006 02:35 PM
06-22-2006 02:38 PM
07-29-2015 02:52 PM
Is there any way you guys can upload a picture of the vi
07-29-2015 06:37 PM
You need to ask more loudly. Neither of those persons have logged into the Forums since 2007.
This is basically what you are being told in your thread.
Lynn
07-29-2015 07:03 PM
Yikes. That's quite the zombie thread bump.
Really, what part of the advice would you benefit from seeing a picture?
They gave two steps:
1) read the entire file
2) get rid of what you don't need
The first results in an array. The second can easily be handled with an array subset function. What picture will help there?
07-30-2015 08:35 AM
Figured out a way that would work for me,
Thanks guys!
12-04-2018 01:07 PM
Does anyone know the name of the VIs they are using? I've got the same issue... I have a .csv and i want to start reading information at line 16.
12-04-2018 01:38 PM
Read text file, Match Regular Expression, Spreadsheet String To Array, Transpose 2D Array.
12-04-2018 02:17 PM
Thank you. "Unfortunately"/Fortunately I had just figured it out and hadn't gotten back to clarifying it here. I'd just like to point out to anyone that you can only use Match Regular Expression "R50" in the picture if you know what the Header ends with in this particular case. The individual was searching for R50, which is how their header terminates.
