05-30-2012 02:16 AM
Sorry I can understand.One more question.
Is there any underlying frameformat in VISA for serial transmission??
05-30-2012 09:12 AM
That is a senseless question. There is of course formatting associated with serial transmission and you have been using it - baud rate, parity, data bits, etc. What do you think those parameters are? Have you done any basic research on RS-232 communication.
05-30-2012 01:44 PM
Danil,
Have you taken any of the LabVIEW tutorials?
I would have thought after posted more than 200 times on the forums, you would have learned something from the responses about basic LabVIEW. As Rolf just said, you don't seem to be reading any of the responses you get. He told you about the \code display back in messge #45 of this thread. Yet you don't seem to remember that!
06-01-2012 01:49 AM
Did a wide search in rs232 communication and VISA.I strongly believe I can learn the thing(but little by little ).Sorry for asking stupid questions.
I did VISA reading and writing as shown in the attached VIs(write continuously.vi & update continuously.vi).I would like to ask,how can we make it possible to read using VISA if the array values are changing continuously,that is in the form as shown in changing array.vi??
06-01-2012 02:11 AM - edited 06-01-2012 02:11 AM
Hi danil,
again a basic question that can be solved after reading the basics/introductory course for LabVIEW...
You have one VI to generate some array data. You have a second VI to send those data to the serial port. Now you ask how to combine them?
Well, I would use the first VI as a subVI in the second - after deleting the (main) loop of the subVI-to-be...
Did you ever notice that "cleanup" button in the BD menu? It really helps on your little VIs...
06-01-2012 03:07 AM - edited 06-01-2012 03:09 AM
Instead of the fixed array in the write continuously.vi we have to use an array whose values are changing.If we remove the loop of the sub-vi,(that is loop of changing array.vi)how the values in the array get change?
06-01-2012 03:12 AM - edited 06-01-2012 03:12 AM
06-01-2012 03:42 AM
I made the sub-VI as shown in the attached VI.It is not working.Is there any changes that we have to make with VISAwrite??
06-01-2012 04:22 AM
06-01-2012 04:39 AM
sorry,see the attachment
