Read data from excel. Build wavefrom.
Hi all,
      I'm trying to generate signals from excel in labview. I cannot figure out how to read data from excel than build it as a waveform. I tried the " read from spreadsheet.vi" and " build waveform vi". It doesn't work. It's super helpful if someone could tell me how to make the vi or make an example. My example excel file is in attachement.
Thank you so much,
Laffer
(2,827 Views)
Accepted by topic author laffer
You cannot read a native Excel file with that function. It reads delimited text files. Save the file in that format or use ActiveX to read Excel.
(2,818 Views)
(2,642 Views)
Hi mdjaved
I have same problem, I do not know how to use ActiveX to read Excel, can you please tell me your solution?
THANKS IN ADVANCE
(2,543 Views)
Hey gentlemen,
these are your options:
- Do it yourself: get started with the ActiveX examples that ship with LabVIEW (Help->Find Examples->Search "ActiveX"). Find more info here: http://www.ni.com/white-paper/3520/en/ and here: http://forums.ni.com/t5/BreakPoint/Excel-Board/td-p/379682
- use the Report Generation Toolkit that now ships with LabVIEW Full: http://www.ni.com/white-paper/3178/en/
- use our commercial Tool "XLR8" that does not require Microsoft Excel to read and write xlsx files. Download it for a free trial from the LabVIEW Tools Network: http://www.ni.com/labviewtools/xlr8 - Get started using the Quick Reference Guide to be found here: https://decibel.ni.com/content/docs/DOC-30645
Peter
CLD | Alliance Partner | Web data storage and visualization | daq.io
(2,480 Views)
