12-10-2012 09:27 AM - edited 12-10-2012 09:28 AM
If your format is always the same and will never change (i.e. same number of characters preceeding $), consider using a tag placement, that is, keep track of how much data is received/recorded, that is to say, occurrances. For instance, you just made your 4th recording, you could store this counter into an FGV or feedback node, then when you read the file back using a FOR loop, you would search for $, and when you have iterated through until your iteration count equals your stored count (number of occurances of $ found = counter), you can extract the data at that location in the file.
An easier way would be to simply take your count and multiply by 127. This would give you your offset file position.
You could use a modification of this idea, using the $ as a delimiter, as has already been suggested along with a count value.
12-11-2012 12:46 AM
Thanks Mr.. johnsold you idea works wonderfully...
