Read TXT and separate data
Hello
I have a problem...
I have this TXT file
T1 1 00000010 00000001 OutIn t1
Ters 1 00110000 00000011 OutIn t2
ggfd 1 00000001 00000010 OutIn t1
t1 0 00000110 00000011 InOut t1
t2 0 00110100 00000011 OutIn t1t2
T1 Tab 1 Tab ..... t1 CR LF
I read this file in Labview and i wuold separate this data for type..
Row 1 in Array [1][1] T1 [1][2] 1 Array [1][3]00000010 ecc...
Array [2][1] Ters
Thx
If you wuold I sand Picture and schematic
Bye
Message 1 of 15
(3,698 Views)
Needs more information, what you want to do with your file,
do you want to splitt into different columns?
Attach sample file and the code that you have tried, to help in better way.
Message 2 of 15
(3,694 Views)
Hi Andrea,
quite easy:
Please get used to "standard" array indices: the "upper left" element has index [0, 0]!
Message 3 of 15
(3,689 Views)
image.pngWhy after Spreadsheet string to array is Orange?
I have try but i don't understend
Thx for answare
Message 4 of 15
(3,683 Views)
Hi Andrea,
Did you read the LabVIEW help for this function?
Do you know all it's inputs and their default values?
Message 5 of 15
(3,680 Views)
help.pngYes I have read, but your is ALL pink (string) and my ist String inizialize and after Orange, I have not select right?
Sorry my Enlglish is not Top....
Thx
Message 6 of 15
(3,677 Views)
Hi Andrea,
did you notice the "Detailed help" link? Did you read the full story?
You know how to create constants in the block diagram, don't you?
Message 7 of 15
(3,674 Views)
Hope You need to specify the array type you need (Default 2D Double).
If you are not passing any value or array type by default it will give 2D Double.
Provide String array to get string values as output
As Suggeted by Gerd Make sure you are provding all inputs/Proper type.
Post code or code snippet not the image
Message 8 of 15
(3,668 Views)
@andreabello wrote:
=Yes I have read, but your is ALL pink (string) and my ist String inizialize and after Orange, I have not select right?
Hope its better to know about datatype instead of refereing colour
Message 9 of 15
(3,666 Views)
Yes i have read all and i now what is a costant ...
But is my first time whit LabView ... I programm normaly and is so different
Message 10 of 15
(3,640 Views)
