Thank you the post. Apologies for the delay in the reponse of the post.
I am unfamilar with the "VT_CY" data type, but I think it does represent a currency string. How are you trying to pass the data type through the dataSocket read vi? Can you post a vi snippet?
thanks for the reply. I have more or less solved the problem by some reverseengineering. I found a OPC client that could read the data to compare with. I read the data as a variant (think it was 64 bytes....) and looked for the hexadecimal values that gave the right value and converted those. its not pretty, and a little shaky, since i don't know if it will work in all cases.
