10-12-2012 11:38 PM
Hi guys
I have Ni USB 6210 which is 16 bit 250 kS/s Multifuntion I/O
Now i have to read digital input which is comming at 10 KHz rate(the clock is 10 KHz and at each raising edge i have to read the value which is avalible at another input line)
But the example which are shiped with are not really helpful for my use
Do anyone has any code or link which can be useful
Thanks in advance
Niladri
P.S I dont have RTOS or any RT module even RT modulation toolkit so can it be possible..
10-16-2012 05:48 AM
10-18-2012 02:58 AM - edited 10-18-2012 02:58 AM
Actually I, some how able to write some code but it is showing an error "Property not available for the device". What does it means ?
Thanks in advance
Niladri
10-18-2012 03:13 AM - edited 10-18-2012 03:13 AM
10-18-2012 07:28 AM
The Device is USB-6210 and error comes in the digital trigger.vi and yes I try almost everytype of application that I can think of and I changed the vi as per your recommendation but still the error persists and it says "Specified property is not supported by the device or is not applicable to the task"
Thanks in advance
Niladri
10-18-2012 07:34 AM - edited 10-18-2012 07:36 AM
10-18-2012 07:42 AM
It is not AI it is Digital input and I am connecting to PFI SRC should it be connected to PFI Gate???
Thanks in advance
Niladri
10-18-2012 07:47 AM
Hi Newbee,
yes, it's a digital input that is used as sample clock for an analog input.
AFAIK MAX will show you how to wire that when creating a task in MAX...
Have you considered calling NI when having problems with your hardware?
10-18-2012 07:56 AM
I got a loner kit from NI after 1 month I have to return it back so I a just testing that this module will serve my purpose or not so no point calling NI for hardware and if you see my vi then I know you can understand where I am making some mistake I am new to LabVIEW.
Thanks in Advance
Niladri
10-18-2012 07:58 AM
