06-23-2009 07:56 AM
I have a program that has a dozen or so different notifiers, and the thick wires going off to the Send Notifications were getting messy. So, rather then using the wire, I just use another Obtain Notifier (named) and thus have a virtual wire. I only do this for the Send Notification function. The Wait on Notification typically occurs in only one place (consumer loop), so it is wired.
Some of these re-obtains occur in loops which may run hundreds of times, and the notifiers are not released until the program, ends.
I'm wondering what type of performance hit I'm taking with this approach? Memory? Speed?
Thanks.
06-23-2009 08:01 AM
Why are you obtaining the reference for each notifier more than once? This is the same approach as file-streaming vs. high level "Write to Spreadsheet".
It definetly has a negative impact on performance, so i suggest you to check out more "streaming like solutions" for the notifiers...
hope this helps,
Norbert
06-23-2009 08:11 AM
Each time you do an Obtain Notifier by name, you will be creating a new reference to the desired notifier (ie causing a lookup to find the object, then creating a small amount of memory to act as a pointer refnum, etc). When looping and not disposing of the notifier, this will cause a small memory build up (not a "memory leak" per say, but additional memory that you dont need).
Therefore, especially in the case of loops, it is more efficient in terms of speed and memory allocations, to do an Obtain Notifier once and then reuse the same reference. If you really dont want to pass the notifier wire to your looping VIs, at least put an Obtain Notifier outside of the loop and pass the reference in along a shift register or tunnel.
This is similar to the whole "avoid creating arrays inside loops" philosophy in that even though it is possible and sometimes easier to use the build array inside a loop, if performance is an issue, it is generally best avoided if possible.
Shaun
06-23-2009 09:02 AM
shew82 wrote:When looping and not disposing of the notifier, this will cause a small memory build up....
Shaun
That's what I thought, but memory manager software is showing that memory is not building, hence my post on here. However, I haven't left it on for several hours. I think I may stick with this configuration for the Send Notifications that only happen a few times.
Thanks for the reply.
06-24-2009 11:18 AM
Hi Broken Arrow,
You will see a performance hit due to the overhead necessary to run the extra Obtain Notifier Functions to create the notifier refnum as well as the auto-cleanup of the refnum when the loop iterates. Because of this auto-cleanup, you won't see too much of a memory build-up, but simply having the extra Functions will add to memory consumption.
Also, to reiterate what shew82 posted, it is more efficient to obtain the notifier once outside the loop and then wire the refnum to each loop thru a tunnel.
As far as releasing the notifier, you only need to call the Release Notifier Function once as long as you have the "force destroy?" input set to TRUE.
Thank you for choosing National Instruments.
Aaron Pena
06-24-2009 11:52 AM
Aaron P wrote:... it is more efficient to obtain the notifier once outside the loop and then wire the refnum to each loop thru a tunnel....
Absolutely, and that's what I've been doing for years, until one week ago, when I did the re-obtain trick in about 20 places and expected a performance hit, and didn't see it. However, i have changed the code back to what is "right" rather than what is "handy". My thought was that maybe the re-obtain just looks up the existing reference rather than actually getting another copy.
Aaron P wrote:Thank you for choosing National Instruments.
It chose me.
