Ramp up, Hold, Ramp Down
Hi Jake,
thanks for response, but since I have LV 2010, can you please re-upload your file for 2010 version?
Actually I did the similar way with yours: using different delay in case structures of ramp up and ramp down.
But would be great to see your idea of course.
Yan.
Message 21 of 44
(1,523 Views)
Yan,
Attached the VI in LabVIEW 2010 for you.
Best,
Jake B.
Message 22 of 44
(1,517 Views)
HI Jake
I have checked your ramp up and down program and it looks quite interesting.
I am new to labview and just learned fairly basic programming skills with labview, I want to acquire a current signal from a circuit and compare the acquired signal with a linear reference signal (this linear signal should be created in labiew only), then adjust the acuired signal in order to make the current signal a linearly ramp up signal. (I have to feed the linear signal which I produced with the labview application into a device/power supply in order to rise the current linearly).
I have acquired the signal with DAQmx and I also created a linear reference signal and I need to compare them and make the adjustment for the acquired signal and then feed it to the power supply. I am actually not sure about the refrence signal which I created and I also do not know how to compare two signals and make the required adjustment. I will appreciate if you help me to complete my program. (I am using labview 2011)
I have attached my program just in case if you need to check it and advice me.
Regards
Mohsen
Message 23 of 44
(1,441 Views)
Does anybody know how we can turn this into an array? Basically change it into a speed table?
Message 24 of 44
(1,328 Views)
what is "this"?
Message 25 of 44
(1,310 Views)
This being the VI that jake posted.
Message 26 of 44
(1,302 Views)
Well, a VI is code and an array is data. You cannot turn code into data, that makes no sense.
If you want to modify the VI to generate an array, you probably want  to autoindex at the loop boundary, but that won't be sufficient in this case, because there is also variable timing, something that would get irreversibly lost if all you keep is the array of values. Clearly, this need to be modified.
(However, Jake's VI is not very good as it stands and it should be rewritten as a simple state machine. Currently there is also an overuse of local variables. None of those are needed if one would place the controls on the toplevel loop diagram instead of deep inside case structure. It is inefficient to place controls like that. Also the small sequence frame has no obvious purpose.)
Maye you should start a new thread and tell us what you need. Your request is sufficiently different to this old thread here. Maybe all you need is to concatenate a few ramp patterns.
Message 27 of 44
(1,285 Views)
Thank you for this nice program. I am wondering how to control the initial current value that is 0 in your program ? The initial current could be 1.5 for example, and final current = 10.I will add a N loop in order to repeat this cycle N times. The period will be 1 cycle of your program. At the end, this will be a triangular wave starting from initial current I0 and reaching a maximum If then going back exactely to I0, repeated N times.
Message 28 of 44
(1,225 Views)
Simplify! As previously mentioned, you just need the Ramp Pattern function.
Message 29 of 44
(1,220 Views)
Thank you  Denis for the suggestion. The RAMP pattern function seems to work for increasing value from I0 to If, not for decreasing.
Message 30 of 44
(1,216 Views)
