Race conditions with UI thread
@Florian.Ludwig wrote:
Hi all,
I'm having a hard time reproducing the error as it happens only very sporadically. I could only do it once since yesterday. But then it kept throwing the error until I stopped the programm.
Since then I have restarted the program numerous times in an effort to reproduce the error to no avail. I can't really test if any measures make it show more or less that way.
The principal error pattern remains the same whenever the error shows:
The instruction inside a sub-vi (in this case an invoke node to display its frontpanel) is not finished but the sub-vi "claims" it is by delivering data to its outputs, therefore triggering other code downstream to execute. If that code is expecting finished execution of the sub-vi there will be trouble.
Is there a way to make sure the code inside a sub-vi is completely executed (even the parts running in the UI thread) before it signals "I'm done" to the rest of the code?
If there was a simple switch, or even a workaound that needs to be placed in the sub-vi in question that would help me tremendously.
Best regards
Florian
I guess you can add a FP.state-property to check/wait until it defacto has opened, or simply add a 100ms wait.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 11 of 14
(481 Views)
that FP.state check will probably solve this specific issue. I will probably go with that or Norberts suggestion of putting the invoke node in the mani vi.
It wouldn't have solved the issue with the x-y graph though.
A general solution for this kind of problem would be nice.
The more I think about it the more I feel that the way this is implemented by NI violates dataflow.
Best regards
Florian
Message 12 of 14
(476 Views)
Update:
I found a way to reliably reproduce the error in my original app. I just close the fp of the sub-vi programmatically downstream.
Mashing the Button to open it fast enough will produce the error quickly.
So I could finally test the following.
Checking for FP.status in a while loop inside the sub-vi until ok: doesn't help Smiley Surprised
Opening the sub-vi's FP in caller: doesn't help
Aligning LabVIEW.exe to one core only: doesn't seem to change the number of clicks needed to produce the error.
Will try to condense this into an example now.
Best regards
Florian
Message 13 of 14
(467 Views)
Update:
No I didn't.
I made a mistake in my attempt to reproduce the issue - sorry.
I'm still working on it.
Best regards
Florian
Message 14 of 14
(424 Views)
