06-28-2017 09:35 AM
Would anyone have an idea why an RT System Session would stop updating only the Total Physical Memory and Free Memory properties? I have a (Very complex) system which reports its memory and disk. This morning, I noticed it had stopped updating only the memory values (Disk values were updating properly). So I wrote this:
To see if what I was seeing was real. This also showed no updates to the physical memory values. When I restarted the RT controller (PXIe-8135RT, LV2016 RT), it started to update properly (This has been working for almost two years without issue).
Very weird...
Thanks!
06-29-2017 07:59 AM
Was the physical memory frozen for long periods of time? Could it be that the total physical memory was not changing during that time period?
06-29-2017 08:40 AM
No, I can't imagine that would be the case. My system seemed to be operating fine otherwise during this situation. I could start and stop acquisition tasks, record to disk, generate logs, receive and transmit CCC/CVT, etc...
Normally, when I do those operations, I watch the RT memory to make sure there's no slow leakage (Slow downward ramp in memory availability). The second to second memory generally fluctuates a little, especially when starting and stopping DAQmx tasks. During this issue though, no memory changes reported at all. Only once I rebooted the RT system did it start reporting again.
I'm going to keep a watch out for this. It's a bit disconcerting...
