09-10-2014 05:45 AM
Hello All,
Now I am working on a project about zigbee which is powered by 24V AC.so I need to control the AC power which can be communicated by RS232.
Most of setup steps are set succussfully,except send "D0:0650:0400:0600:2200:0150:0500:4600:0100:0:0/ "
I tried many solutions to write this string, convert into Hex then send,or send this string separately,send D0 first,then send :650 etc...
However,sometimes the eqipment can be controlled,sometime it can not.
Any hints are appreciated,thanks
09-10-2014 06:32 AM
MY VI,FYI
09-10-2014 06:34 AM
The protocol
09-10-2014 07:02 AM
... and what error do you get on the odd one?
Blog for (mostly LabVIEW) programmers: Tips And Tricks
09-10-2014 07:33 AM
Hi Albert,
what you named "protocol" is just example data without any explanations.
Your "D0:..." string looks ok, it's just plain ASCII data. This "OK" answer is also plain ASCII.
Don't you have a more detailed manual with some real protocol descriptions? If not ask your vendor for this manual!
09-10-2014 07:48 PM
Hi GerdW,
The communication protocol is written by Chinese which is attached.
发:means send command
收:means receive response
Please take a look at "2.参数设定" ,only this step always get error after write "D0:0650:0400:0600:2200:0150:0500:4600:0100:0:0/" ,not get "OK/" response.
There is no issue on write/read others steps except "2.参数设定 ".
Best regards
Albert
09-10-2014 08:00 PM
