06-04-2014 02:14 PM
I'm trying to visualize the data from a Mastech MS2203 in LabVIEW using RS232 serial port.
I have the initial config settings (baud rate, parity etc...) that I could get using PORTMON, but I'm still no sure what to do next.
I couldn't find the serial protocol for this device, but I have their software that does exactly what I'm trying to do.
I have attached the software display and the PORTMON data that I got while I was running the program.
Does anyone have any ideas on what I could do next?
Thank you!
Solved! Go to Solution.
06-04-2014 05:18 PM
Need to get the serial protocol specification from the vendor of the Mastech MS2203 to know how to parse the hex data.
620.00000310DigitPower.exeIRP_MJ_READSerial0SUCCESSLength 22: 05 05 10 04 E0 FB 60 60 05 44 28 EB ED FD CF ED 60 00 00 00 1F
06-04-2014 05:21 PM
You will find your answer here: http://www.multimeterwarehouse.com/MS2203Protocol.pdf
06-04-2014 06:51 PM
That's not exactly readable.
06-05-2014 01:10 PM
Thank you Matthew!
With that file and a little help from Google Translate I could read the voltage in LabVIEW.
06-05-2014 01:27 PM
Glad I was able to help out. Good luck!
12-21-2015 10:23 PM
dear,
i also facing same problem.can you share your labview file for this instrument to me.
my email id is- ashutoshpatelm@gmail.com
12-24-2015 01:53 PM
Dear patel1508,
I don't have the code for this multimeter anymore, sorry.
But I remeber I used the code provided in this post as a starting point for my application:
You'll have to change some parameters to work with the mastech device, but you'll be able to have a pretty good idea on how to do it
hope that helps.
Kenny
