03-03-2017 01:44 AM
We want to connect our cRIO to our host-PC on a distance of about 200m.
Ethernet supports max. 100m. So is there a way to use RS-485 communication,
which allows for larger distances?
Or do you have other suggestions?
Thx,
Thomas.
03-03-2017 01:50 AM - last edited on 04-05-2024 02:38 PM by Content Cleaner
Hi Thomas,
So is there a way to use RS-485 communication, which allows for larger distances?
NI sells a cRIO module with RS232 and RS485 interfaces…
Use a repeater for your LAN connection!
Or use glass fibers…
03-03-2017 01:52 AM
Thanks for your suggestions.
Regarding the Rs485 cRIO module : Can this module also be used to do the host communication instead of the onboard ethernet NIC?
03-03-2017 02:13 AM
