04-03-2017 03:35 AM
Hi everyone. I need trying to figure how to go about this situation. I created a VI which saves data in a spreadsheet. The data has 25 rows and 3 columns. Then I had read the data from the spreadsheet and display graphically. The first column is " Voltage", the second column is " Amps", and the third column is " Power".
I want to be able to display two graphs: One is" Voltage Vs Current" and the other is "Voltage vs Power"
If any one can provided me with some guidance, I will really appreciate it.
Vincent
Solved! Go to Solution.
04-03-2017 03:42 AM - edited 04-03-2017 03:43 AM
04-03-2017 04:55 AM
Try this
04-03-2017 05:02 AM
Thanks GerdW,
I am going to give it a try and provide you with a feedback.
04-03-2017 05:20 AM - edited 04-03-2017 05:20 AM
04-03-2017 05:52 AM - edited 04-03-2017 05:53 AM
Hi Gerd You are rite... Thanks for reminding.
04-03-2017 07:47 AM
Hi Palanivel,
Thanks for the help. The only thing I could not find was the figures attached to the For Loops. Are they supposed to X-Y Graph symbols of something else?
Thanks.
Vince
04-03-2017 08:14 AM
04-03-2017 10:56 AM
04-04-2017 03:06 PM
Thanks are given with kudos, and marking solutions.
Get going with G! - LabVIEW Wiki.
16 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
