RAD Utility on Remote Formatted cRIO
Hi everybody, I have a remote cRIO formatted connected to a Host Pc without NI Drivers, Labview RT, Labview FPGA and so on.
Here in my office I developed a startup RT application without cRIO (!!!) and I would send it to my remote cRIO. I used also component definition but it does not include drivers and software...
Is it possible to use the RAD utility creating before a "virtual" image? Or, there are any chance to include also drivers and software into my RTapplication?
(2,599 Views)
you could connect with your remote compactRIO and install software and drivers on it; in this way you should work having the connection established between your PC and the target.
If for some reasons you couldn't connect remotly with the compactRIO, you have surely to configure another target with your PC, create an image and send it to the remote target on which you have in any case to install RAD and all required softwares.
I attach a usefull link: http://www.ni.com/example/30986/en/
Regards
(2,558 Views)
